Hello from UK
<< < (3/3)
Lillifee:
[quote Baxter]Where would I look for steering geometry data?[/quote]
Ich denke Baxter sucht Informationen zur Spur-Einstellung ... Ich hab' da keinen Dunst
Baxter:
I think only tracking is adjustable, and I can always just set to zero.
Snoop:
Hi Simon,
at the front axle there is only one tie-rod adjustable (right-side).
You need to set the left front-wheel (0), clamp the steering wheel
and adjust the right tie-rod to (0) (+5° to -5°) for the complete track.
The rear axle has adjustable tie-rods for both wheels.
Setting: -25° to +5° for the complete track.
If you see positive or negative vertical differences - learn to deal with it
and welcome in the X-wheel club! ;)
VW used to have bushings with excentric holes for that problem, but they are out of stock since years...
Administrative order:
Please do not become to much off topic in your threads.
This is a "Hello from UK" thread,
nobody expects technical questions at the end of it...
Hope you understand.
MacSchreck:
Hello,
the number for the exentric bushings is 183 407 181 A. Try to get some, tell me if you could.
Greetings
Baxter:
*Wrists slapped*
Navigation
[0] Themen-Index
[*] Vorherige Sete
Zur normalen Ansicht wechseln
