Autor Thema: mefros on!  (Gelesen 2421 mal)
Offline Baxter
mefros on!
« am: 18. September 2010, 00:14 »
The body went back on the chassis (loosley) yesterday, had a little time after work so I put my new wheels on.
Mefro 6x16 ET30
205/16 Hankook RT01 tyres (very similar to BF Goodridge AT's)
Appologies for rubbish phone picture.
I used conversion studs all around and used the correct wheel nuts with the correct seat (mercedes style) for the wheels.
Surprisingly you can still turn the steering wheel!
I just hope the Reduced offset doesn't make it drive strangley!
Re: mefros on!
« Antwort #1 am: 18. September 2010, 07:15 »
Hi Simon,
nice wheels!
I think the Mefros are very similar to the T3 Syncro 16" steel-rims,
which are officially approved by the VW company to be mounted on the Iltis.
The big difference is the spread.
Syncro = 5,5"
Mefro = 6,0"
On my Iltis are VW Bus T4 wheels 6 x 16 ET53
Because of the "deep" ET53 and the different hub-drilling I also had to mount aluminium spacers.
The advantage with spacers was, I could "adjust" the wheels till the tires fit to the fenders edge...
By the way, what colour does your Iltis have?
Looks like a light brown on my monitor.
Offline Baxter
Re: mefros on!
« Antwort #2 am: 19. September 2010, 22:03 »
Yes, The Mefro's are very similar to the T3 16" items.
Another company under the Mefro banner is "Kronprinz", They make wheels for OEM, if you look at a lot of VW wheels they have KPZ stamped into them, this is Kronprinz so we know the Mefro are excellent quality and well up to the use I will put them to!
With these wheels and 205/16 the tyre treads are just inside the arch, they are perfect, as far out as you can safely go without having to use a wheel arch extension.
The colour is VW L319 I presume, RAL6014, it is quite old and has been painted several times, the picture was under fluro light at night with a camera phone, so I wouldn't take too much notice of your monitor!
:p
Offline Baxter
Re: mefros on!
« Antwort #3 am: 19. September 2010, 22:57 »
More pictures of the rims here, and a little update of the last week.
<< Click >>
Re: mefros on!
« Antwort #4 am: 20. September 2010, 19:23 »
Yes, the wheels are precise at the right position !!!
Perfect job!
If your 205 R16 tires are down, you can upgrade to 225/75 R16.
Like this:
BF Goodrich 225/75 R16 on VW Iltis
Offline Baxter
Re: mefros on!
« Antwort #5 am: 20. September 2010, 23:25 »
That's a pretty truck.
Offline Baxter
Re: mefros on!
« Antwort #6 am: 11. Oktober 2010, 23:19 »
Okay, you got me!
What are the centre caps on those wheels?!
Re: mefros on!
« Antwort #7 am: 12. Oktober 2010, 07:11 »
[quote Baxter]
What are the centre caps on those wheels?![/quote]
2KO 601 169   9B9 Radz. Kappe  (I tink they re from the actual VW Caddy light-truck)
Offline Baxter
Re: mefros on!
« Antwort #8 am: 12. Oktober 2010, 22:08 »
Great info, thanks!
I take it 2009> caddy is 5x112 PCD?
Some nice 16" steels on e-bay locally to me, interesting winter wheels for something.
