Autor Thema: Heater is leaking  (Gelesen 1828 mal)
Offline Finnish Iltis
Heater is leaking
« am: 26. Februar 2023, 10:12 »
Heater is leaking, there was small amount water on the floor and bottom of black cover element was wet under. Do you know if heater-parts are same for example in golf, passat.... Is there some typical part which could leak?
Offline otto
Re: Heater is leaking
« Antwort #1 am: 27. Februar 2023, 09:33 »
VW Polo 86 C
Offline rouvi
« Antwort #2 am: 27. Februar 2023, 21:01 »
5901532292329, 73964, 812029, 861819121, 861819121A, 867819121, 867819121A, 8FH351313341
« Antwort #3 am: 01. März 2023, 10:33 »
Thanks
Offline clusterix
« Antwort #4 am: 01. März 2023, 17:35 »
Hej
Keep always an eye on the regulation valve - often is the gasket from Valve flange to the Heat exchanger worn/leak or the valve itself is leaking..
MvH
Sønke
« Letzte Änderung: 01. März 2023, 17:37 von clusterix »
Grüsse
Sönke
