Autor Thema: Light switch.  (Gelesen 1807 mal)
Offline Baxter
Light switch.
« am: 28. September 2010, 21:44 »
I'm not normally a retard, but I'm struggling with the light switch!
How do you switch from civilian lights to military lights?
I've not seen any instructions, but I presume you flick some sort of lever to switch between the 2 modes, although mine seems stuck.
is there a knack?
Re: Light switch.
« Antwort #1 am: 28. September 2010, 22:02 »
Did you try to slide that "bar" to the left?
After that, you can twist the switch counter clock wise for black out lights.
Offline Baxter
Re: Light switch.
« Antwort #2 am: 28. September 2010, 22:05 »
I think it must be jammed then!
I will hit it harder!
i thought that's how it should be but the bar is stuck fast.
Thanks.
Offline Berserker
Re: Light switch.
« Antwort #3 am: 29. September 2010, 13:47 »
Muss man den Schalter nicht drücken um das "Schnäpperle" verschieben zu können? So ists zumindest bei mir.
You have to push the switch-> hold this position and then you can move the "bar".
Don t forget to press the switch because the switch breaks, otherwise
Offline Baxter
Re: Light switch.
« Antwort #4 am: 29. September 2010, 23:45 »
I will stop hitting it then.....
:eek
Offline Baxter
Re: Light switch.
« Antwort #5 am: 05. Oktober 2010, 00:16 »
Switch works fine, once you know to push it!
Many thanks.
