Autor Thema: Woo, yeah!  (Gelesen 4343 mal)
Re: Woo, yeah!
« Antwort #15 am: 24. Januar 2011, 08:35 »
the rearmost tubes of the roll bar are rectangular rather then round, to grant the neccessary 4cm more clearance for the two stretchers side by side
Offline Baxter
Re: Woo, yeah!
« Antwort #16 am: 24. Januar 2011, 22:33 »
I wonder if this Iltis is a miss match of parts then?
Why would it need the roll over bar from a medic car if it still has it's jerry can and spare wheel on the rear?
It left as a standard Iltis, but it hass the roll over bar and red cross signs, but a standard hood?
It also has rear seats.
The VIN matches the one on the plate under the body so the body and chassis are correct.
hmm.
Re: Woo, yeah!
« Antwort #17 am: 25. Januar 2011, 09:00 »
you have holes in the rear right fender?
this was a former ambulance!
there was the spare wheel fixed.
most of the medics were retransformed by bundeswehr, as there was no real need for them in the 90s.
but the rollbars always stayed
for the hood, there was a doorsack with cross printed on it
First it was an ambulance car ...
« Antwort #18 am: 25. Januar 2011, 11:13 »
Hello Simon,
you wrote that you've found red crosses under the paint:
Zitat von: Baxter
The bonnet has a big red cross under the paint, and the rear panel, and rear 1/4 panels also have red crosses painted over.
You've got an ambulance roll over bar, two holes at the side, ... -> Your Iltis was certainly first produced as a a medic vehicle (You've also got no trailer hitch - do you?).
And later it was used in other content -> Therfore they put rear seats in, ...
I think this is (one part of) "the story" of your car.
FYI: On this picture you can see an "usual" roll over bar of an Iltis (= "round" back brackets): Example
Re: Woo, yeah!
« Antwort #19 am: 25. Januar 2011, 11:15 »
[quote Baxter]I live in Yorkshire, our accent is quite "broad", I should imagine it's pretty much the same wherever you go? I'm sure you can tell where someone is from from the way they speak?[/quote]
Yes - it makes (among other things) our life colourful. :)
Alternative Iltis-parts
« Antwort #20 am: 25. Januar 2011, 12:43 »
Hi Simon,
Perhaps this canadian site is interresting to you (?): http://www.oocities.com/iltisvw@rogers.com/Iltistrickspage.html
(Don't be amazed - The loading of the page takes very very long because it's an old one / it's archived; therefore also the pictures are missing :( ...)
In the meantime you can cast an eye on the "Original" if you want ;): http://gunther.biernat.info/wiki/index.php/Alternative_Ersatzteile
Re: First it was an ambulance car ...
« Antwort #21 am: 25. Januar 2011, 18:02 »
[quote Lillifee] (You've also got no trailer hitch - do you?).
No Volkswagen Iltis had a hitch as standard, I guess.
« Antwort #22 am: 25. Januar 2011, 19:59 »
Hi Oliver,
Hmmm - you may be right ...
As an evidence: You will find all (?) military accessories like blackout lights, gun brackets etc. in the ETKA - but no hitch. (In contrast: In the "belgian ETKA-Version" the hitch is pictured)
P.S.: Hell! Damned! My english is so lousy ... ;)
Offline Baxter
Re: Alternative Iltis-parts
« Antwort #23 am: 25. Januar 2011, 22:46 »
Thanks for all your interest, experience and insight!
I don't come from a culture where things were swapped about so much, I just imagine piles of standard roll bars just sat there, or old ambulance hoods, seems a little wasteful.
I always finish my plate ;)
Interesting link, I will take a look shortly.
Offline Baxter
Re: Woo, yeah!
« Antwort #24 am: 28. Januar 2011, 14:23 »
MOT'd, Taxed, registered, on the road and in use!
Quite cold though, need to sort the roof and doors!
Offline Baxter
Re: Woo, yeah!
« Antwort #25 am: 29. Januar 2011, 21:41 »
Offline Baxter
« Antwort #26 am: 30. Januar 2011, 00:15 »
I presume it looked like this at some point then?
http://www.primeportal.net/trucks/ulrich_wrede/vw_iltis/
« Antwort #27 am: 30. Januar 2011, 11:16 »
Moin Simon,
yes, but it had a special hood. F.e. look here:
http://www.panzerbaer.de/helper/pix/bw_lkw_00-5t_tmilgl_vw_krkw_1985-001.jpg
http://www.sebastianh[b]ä[/b]rle.de/images/bw/iltis.jpg
(You have to copy the second link manually to your browser because the software of this forum doesn't support the newer www-adress-elements like "ä", "ö", "ü", ...)
Cheers
Volker
Re: First it was an emergency ambulance
« Antwort #28 am: 30. Januar 2011, 12:56 »
Semi-off-topic:
I wouldn't like to be transported in this ambulance, with my body's centre of gravity behind the rear axle, and with the supershort wheelbase.
That's why it was always called an emergency ambulance.
Offline Baxter
Iltis progress video
« Antwort #29 am: 03. Februar 2011, 00:27 »
