Autor Thema: Prop shaft - for the WiKi?  (Gelesen 2011 mal)
Offline Baxter
« am: 25. Januar 2011, 23:22 »
After getting my Iltis running, I notices a noisy joint on the drive train.
Today I removed the prop shaft (cardan shaft?)
I have measured it and spoken to GKN.
Dimesnions
25 splines
32mm deep
100mm outer diameter
6 holes
86mm PCD (bolt circle)
holes to suit 8mm bolts.
Loebro No - 301142
But then that number crosses over to lots of items!
ALFA ROMEO  0004315132
ALFA ROMEO  0009936769
ALFA ROMEO  0060806930
ALFA ROMEO  0082282139
ALFA ROMEO  0092601388
ALFA ROMEO  0092601892
ALFA ROMEO  4315132
ALFA ROMEO  60806930
ALFA ROMEO  82282139
ALFA ROMEO  92601388
ALFA ROMEO  92601892
ALFA ROMEO  9936769
FIAT  0001493963
FIAT  0004315132
FIAT  0009936769
FIAT  0046307129
FIAT  0060806930
FIAT  0082282139
FIAT  0092601388
FIAT  0092601892
FIAT  1493963
FIAT  4315132
FIAT  46307129
FIAT  60806930
FIAT  72GG4635BA
FIAT  82282139
FIAT  92601388
FIAT  92601892
FIAT  9936769
FORD  1493963
FORD  4315132
FORD  60806930
FORD  72GG4635BA
FORD  82282139
 FORD  92601388
FORD  92601892
FORD  9936769
LANCIA  0004315132
LANCIA  0009936769
LANCIA  0046307129
LANCIA  0060806930
LANCIA  0082282139
LANCIA  0092601388
LANCIA  0092601892
LANCIA  4315132
LANCIA  46307129
LANCIA  60806930
LANCIA  82282139
LANCIA  92601388
LANCIA  92601892
LANCIA  9936769
I am unsure of the heat treatment on the item listed above, the Iltis joint seems to have a black harnened finish, GKN do not have a listing for this part so they could not confirm if the item listed above.
The part above is dimensionally correct, it will bolt on and work.
Re: Prop shaft - for the WiKi?
« Antwort #1 am: 26. Januar 2011, 08:13 »
you should remember that wheel joints do not properly work in cardan joint due to different angle of work
Offline Baxter
« Antwort #2 am: 26. Januar 2011, 22:45 »
hmm, GKN themselves gave me the part numbers and did not mention this?
Maybe it's the black industrial finish on the joint that makes this different from a normal constant velocity joint?
I will ask further..
« Antwort #3 am: 27. Januar 2011, 08:28 »
computerpeople :)
just disassemble the two joints (prop + cardan) and compare the ball paths
there you will see a very varied path
« Antwort #4 am: 27. Januar 2011, 13:39 »
Sorry, Tobi-Iltisteile,
I don't understand your arguments.
Of course, one should never use a constant-velocity-joint with a too small max tolerable angle.
But the working angle of the wheel joints is bigger than that of the cardan (=prop shaft).
So, where's the problem?
Oder auf deutsch:
wenn man ein Gleichlaufgelenk mit weniger als dem zulässigen Auslenkungswinkel benutzt liegt man auf der sicheren Seite. Andersrum ist's Mist.
« Antwort #5 am: 27. Januar 2011, 17:51 »
es geht nicht um den winkel, aber um die belastbarkeit
it's not about the angle but about the load capacity
« Antwort #6 am: 27. Januar 2011, 18:59 »
I understand.
It's not the angle (that's what I read from your input yesterday) but the load capacity. Shaft has to drive two wheels.
