Autor Thema: Mechanical fuel pump.  (Gelesen 1757 mal)
Offline Baxter
« am: 23. April 2012, 22:53 »
Okay.
I bought an iltis of unknown condition.
I decided to put a diesel in it.
I never used the petrol engine.
I replaced the fuel lines with polyamide tubing and removed the electric fuel pump.
We used the iltis for 1 year.
The diesel engine developed a nasty noise and we decided that the diesel engine is not suited to a standard iltis gearbox, so we are currently preparing the original petrol engine to be put back in.
I thought it would be simpler to use a mechanical fuel pump rather than chop my fuel lines around only to find the electric fuel pump doesn't work.
So, I removed the blanking plate from the engine block but the fuel pump does not fit as it touches the vacuum advance unit on the ignition distributor.
Has anyone fitted a mechanical fuel pump on a 24v iltis? Did you have any clearance problems?
Or, did you turn the cam belt one tooth on the intermediate shaft and turn the distributor away from the pump?
Offline Baxter
Re: Mechanical fuel pump.
« Antwort #1 am: 23. April 2012, 22:55 »
Oh, incidentally, the noise on the engine was simply a loose flywheel, even though we used new bolts and torqued them correctly.
Never had that before!
« Antwort #2 am: 23. April 2012, 23:49 »
Is this usefull to you?
Mechanische Benzinpumpe
It´s an already existing theme.
Greetings
Offline Baxter
« Antwort #3 am: 24. April 2012, 00:01 »
Yep, that's it!
I think it maybe the brand of fuel pump I have used.
The one pictured looks a little smaller than the one I have.
Clean I up, put it back in the box and back it goes!
Offline Baxter
« Antwort #4 am: 25. April 2012, 15:09 »
In the end I dusted off the electric fuel pump and fitted some banjo fittings to the polyamide fuel line.
All appears to be working.
I couldn't get a mechanical fuel pump here that did not foul the distributor.
