Autor Thema: Testing the fuel level sender?  (Gelesen 1821 mal)
Offline Baxter
« am: 21. Juni 2012, 19:06 »
Does anyone know what resistance readings I should get from the Iltis fuel level sender unit?
My gauge ready very low.
I have bridged the connections at the sender unit and achieved a full tank, disconnected it is empty, I'm fairly sure the wiring and gauge are okay.
I have removed and inspected the sender unit and nothing appears to be broken and there is a circuit through it, I think there must be a high resistance somewhere.
I have looked through the Wiki [as best an English man can!] but couldn't find anything.
Simon.
Re: Testing the fuel level sender?
« Antwort #1 am: 21. Juni 2012, 22:27 »
Did you read this?
Due to the level (left) the sender unit suppose to have the (right) resistance.
The Wiki recommend to clean the contacts with e.g. a wire brush or sand paper to avoid a too high resistance.The resisitance from contact to contact suppose to be 80 Ohm.
If do you need any further translation of the Wiki, don´t hestiate to ask!
Offline Baxter
« Antwort #2 am: 22. Juni 2012, 20:26 »
Cheers buddy! I couldnt find it, just what I needed, many thanks.
(tu)
Offline Baxter
« Antwort #3 am: 25. Juni 2012, 22:39 »
Hi.
I had 10 minutes spare after work today so I removed the fuel level sender.
I tested the resistance as per the data in the Wiki.
I found that all the readings were 130? too much.
I then found a high resistance between the connection terminal and the brass rivet that goes through to the inside of the sender unit.
It was 130? !!
So, tomorrow I will soda blast this area and try and get some solder on without melting the insulation.
Almost fixed.
Offline Baxter
« Antwort #4 am: 26. Juni 2012, 23:24 »
All repaired.
Working again.
Fixed by a simple blob of solder between the terminal and the rivet.
All good again.
(tu)
« Antwort #5 am: 27. Juni 2012, 17:55 »
(tu):D
