mefros on!
Begonnen von Baxter, 18. September 2010, 00:14
Baxter
The body went back on the chassis (loosley) yesterday, had a little time after work so I put my new wheels on.
Mefro 6x16 ET30
205/16 Hankook RT01 tyres (very similar to BF Goodridge AT's)
Appologies for rubbish phone picture.
I used conversion studs all around and used the correct wheel nuts with the correct seat (mercedes style) for the wheels.
Surprisingly you can still turn the steering wheel!
I just hope the Reduced offset doesn't make it drive strangley!
Hi Simon,
nice wheels!
I think the Mefros are very similar to the T3 Syncro 16" steel-rims,
which are officially approved by the VW company to be mounted on the Iltis.
The big difference is the spread.
Syncro = 5,5"
Mefro = 6,0"
On my Iltis are VW Bus T4 wheels 6 x 16 ET53
Because of the "deep" ET53 and the different hub-drilling I also had to mount aluminium spacers.
The advantage with spacers was, I could "adjust" the wheels till the tires fit to the fenders edge...
By the way, what colour does your Iltis have?
Looks like a light brown on my monitor.
Baxter
Yes, The Mefro's are very similar to the T3 16" items.
Another company under the Mefro banner is "Kronprinz", They make wheels for OEM, if you look at a lot of VW wheels they have KPZ stamped into them, this is Kronprinz so we know the Mefro are excellent quality and well up to the use I will put them to!
With these wheels and 205/16 the tyre treads are just inside the arch, they are perfect, as far out as you can safely go without having to use a wheel arch extension.
The colour is VW L319 I presume, RAL6014, it is quite old and has been painted several times, the picture was under fluro light at night with a camera phone, so I wouldn't take too much notice of your monitor!
:p
Baxter
More pictures of the rims here, and a little update of the last week.
<< Click >>
Yes, the wheels are precise at the right position !!!
Perfect job!
If your 205 R16 tires are down, you can upgrade to 225/75 R16.
Like this:
BF Goodrich 225/75 R16 on VW Iltis
Baxter
That's a pretty truck.
Baxter
Okay, you got me!
What are the centre caps on those wheels?!
[quote Baxter]
What are the centre caps on those wheels?![/quote]
2KO 601 169   9B9 Radz. Kappe  (I tink they re from the actual VW Caddy light-truck)
Baxter
Great info, thanks!
I take it 2009> caddy is 5x112 PCD?
Some nice 16" steels on e-bay locally to me, interesting winter wheels for something.
