Light switch.
Begonnen von Baxter, 28. September 2010, 21:44
Baxter
I'm not normally a retard, but I'm struggling with the light switch!
How do you switch from civilian lights to military lights?
I've not seen any instructions, but I presume you flick some sort of lever to switch between the 2 modes, although mine seems stuck.
is there a knack?
Did you try to slide that "bar" to the left?
After that, you can twist the switch counter clock wise for black out lights.
Baxter
I think it must be jammed then!
I will hit it harder!
i thought that's how it should be but the bar is stuck fast.
Thanks.
Berserker
Muss man den Schalter nicht drücken um das "Schnäpperle" verschieben zu können? So ists zumindest bei mir.
You have to push the switch-> hold this position and then you can move the "bar".
Don t forget to press the switch because the switch breaks, otherwise
Baxter
I will stop hitting it then.....
:eek
Baxter
Switch works fine, once you know to push it!
Many thanks.
