Heater is leaking
Begonnen von Finnish Iltis, 26. Februar 2023, 10:12
Finnish Iltis
Heater is leaking, there was small amount water on the floor and bottom of black cover element was wet under. Do you know if heater-parts are same for example in golf, passat.... Is there some typical part which could leak?
otto
rouvi
5901532292329, 73964, 812029, 861819121, 861819121A, 867819121, 867819121A, 8FH351313341
Finnish Iltis
clusterix
#4
Hej
Keep always an eye on the regulation valve - often is the gasket from Valve flange to the Heat exchanger worn/leak or the valve itself is leaking..
MvH
Sønke
