Track rod end?
Begonnen von Baxter, 27. September 2010, 22:54
Baxter
Hi.
While using my parts search software, I looked up the Lemforder part for the left hand front track rod end.
VW - 183 419 811
Lemforder - 16631 01
The specification is as follows.
Fitting Position Front Axle, Fitting Position Left, Fitting Position Outer, Length 74 mm, Cone Size 14 mm, Inner Thread M14x1,5 mm, with right-hand thread, Weight [g] 0,310 kg, Thread Size M14x1,5
Now, compare that to a MKI Golf item
VW - 171 419 811
Lemforder - 10251 02
Fitting Position Front Axle, Fitting Position Left and right, Fitting Position Outer, Length 74 mm, Cone Size 14 mm, Inner Thread M14x1,5 mm, with right-hand thread, Weight [g] 0,320 kg, With accessories, Thread Size M14x1,5
Now, is it me or is that exactly the same part?
Am I missing something?
I only looked because the MKI Golf item also fits the T3, and doing what I do have have a pile of T3 parts on the shelf!
Baxter
:p
Do you mean I have become "Obsessed"?
Stinkmarder
[quote Baxter]
VW - 183 419 811
VW - 171 419 811
Now, is it me or is that exactly the same part?[/quote]
This is currently discussed in the IltisWiki-Autorenforum:
It is NOT the same part but it seems to fit. The main difference is the thread on the cone. (M12.x1.5)
Regards
Johannes
[quote Baxter]:p
Do you mean I have become "Obsessed"?[/quote]
No, but you are right: Obsessed is what we all are...I ment your research.
Baxter
Did the Iltis have M10x1?
If so i took one of those off a syncro the other day, those really are terrible threads, not strong enough.
I prefer the idea of M12!
